Does OneAgent plug-ins consume Custom Metrics?
I would like to know if in case we active OneAgent pluguins like Rabbit MQ, HAproxy and MongoDB will them cosume custom metrics
skrystosik
Built in plugins that are distributed with Dynatrace does not consume custom metrics. Only if you will create own JMX plugin or upload custom OneAgent plugin, metrics will be used.
Regards, Sebastian
larry_roberts
DynaMight Champion
DynaMight Champion
To add to Sebastians answer, uploading a custom Active Gate plugin will use them as well.
