From the technology support page and a blog article I do understand that it should be possible to track http client requests done in golang via net/http.
I have a custom application that is receiving http requests, mapping/multiplexing them and then doing multiple parallel http client requests against a webservice using the following code (simplified):
// many of these requests are created first newreq,_ := http.NewRequest(req.Method, url, bytes.NewBuffer(payload)) newreq.Header.Add("Authorization", "Api-Token " + token) newreq.Header.Add("Content-Type", "application/json") ... //later the requests are executed resp, err := client.Do(&r)
I'd have expected to see the http client calls on the PurePaths or on the stack but they seem to be not tracked.
The calls are actually made to a Dynatrace Cluster API that is also connected to the same Dynatrace Tenant so I'd have hoped for a service flow from the go "proxy" to the tenant APIs but instead I only see the go service and the incoming call on the Dynatrace API side.
The actual http client requests are done in getRespChan in a go routine.
Any ideas if/how this should work to trigger a Purepath service call?
GoLang Version 1.12.4
OneAgent 1.169
Docker Container no MUSLC
Thanks!
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
