question
Dennis H. avatar image
Dennis H. asked ·
Datapower Plugin Error - "No connection adapters were found for [our url]"
We are currently using Datapower Plugin Version: 1.089. When setting this up, all configurations are accepted and we get the green checkmark.
However, data never shows, and the logs show the following errors(I've masked the URL):
2019-08-22 17:40:00.072 UTC WARNING [Python][9304997945187610746][][139954624485120][ThreadPoolExecutor-0_0] - [getRESTResult] Failed polling: url.url.com:9090 with domain: default
2019-08-22 17:40:00.072 UTC ERROR   [Python][9304997945187610746][][139954624485120][ThreadPoolExecutor-0_0] - [getRESTResult] No connection adapters were found for 'url.url.com:9090'
requests.exceptions.InvalidSchema: No connection adapters were found for 'url.url.com:9090'
Dynatrace Managedextensions
Dennis H. answered ·
SOLUTION for others:
Changed the port to 5550 (9090 is the GUI port) and it worked!
1 comment Share
Good! It was a two step solution because you had to do both changes you ended up doing :)
0 Likes 0 · ·
Michael L. avatar image
Michael L. answered ·
What URL did you fill into the configuration? It looks like you forgot to add http:// or https://
Make sure to fill in the full URL to the XML management interface, the default URL is in the display hint.
2 comments Share
I have updated the plugin to v1.091. Same error is given.
@Michael L. - when I add https://, I receive
Update failed - Error(not well-formed (invalid token): line 2, column 2)
0 Likes 0 · ·
What is the full value you are entering?
0 Likes 0 · ·
Diego M. avatar image
Diego M. answered ·
Hi Robert,
Could you please open a support ticket for this? I believe there is a newer plugin version that may address this issue.
Diego
1 comment Share
0 Likes 0 · ·
