We running at STIME inc a prerender to cache some url when they are requested from the googlebot.
I would like to know if it possible to to disable javascript injection for specific user-agent tag in the https request header (especially for googlebot crawler) or just disable the injection for a selected process group . Additionnaly I would like to know where in the infrastructure the injection take place ?
Answer by Sebastian K. ·
In application settings you can pick user agents that should be monitored
If you know user agent for robots you can exclude monitoring there.
To exclude injection on single process you have to have dedicated process group for it because injection can be disabled on process group level. Go to edit and there you will have proper option. If you have in this process group processes that you still want to monitor you have to split it using proces group detection settings
In general agent should be injected on Webserver that is on frontend. So if you have Apache as reverse proxy for tomcat injection will be there.
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 12, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Register here
Is it possible to filter out JavaScript errors that only occur for a single user? 1 Answer
Pass value from javascript to next synthetic event 1 Answer
dtagent_ICA23STVbdgjpqrsvx_7000000201016.js 404 error 3 Answers
404 error for dtagents in One-Agent 1 Answer
Do Service Request URL cleanup rules and naming rules not work together? 1 Answer
