We need monitor SSL certificate expiry and we want to get the alert X-days before it expires and just if it is expired.
There are same different implementation, for example :
Answer by Sebastian K. ·
In general you will have to create so how metric that will present certificate validation time as number of days. In such way you will be able to create threshold on such metric. But to get such value I think you will have to create ActiveGate plugin that will call your hosts every minute (default behavior), fetch date time of certificate expiration and than calculate number of days. After this operation such data should be send to dynatrace as custom metric with dimensions for all host separately. This will give you option for creating threshold and event for such metric,
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
How does synthetic activegate works and on which port does they upstream the data to the cluster ? 1 Answer
Can the Mandiant agent have a negative impact on monitoring by Dynatrace solutions? 0 Answers
Where a private location synthetic active gate upstream its data 1 Answer
