Incidents / Problems report template for NOC team
snakhuda
Participant
Looking for some guidance on how to build and schedule weekly incidents/problems report for NOC team. It would be great if someone could list down all the steps and a sample template.
API calls to generate problem report (time frame: last 7 days)
Convert report output in excel format
Email weekly report output / link to NOC team
thanks!!
Salman
skrystosik
I think you will have to create dashboards for incidents you have and then use dynatrace option for generating reports based on dashboards.
Regards, Sebastian
Bert_VANDEGAER_
Participant
Use the API call: /problem/feed
and export data regularly into e.g. ELK and report from there?
