Is it possible to export timeseries of Synthetic browser monitor?
yohnishi
Organizer
Hi All,
I am considering about Synthetic alert notification.
Dynatrace can not notify the synthetic alert only by one threshold violation.
(This function is changed form Classic Synthetic. And I request as RFE: https://community.dynatrace.com/idea/225021/view.html.)
Now I think I want to notify with external method. If I can export the synthetic timeseries with Dynatrace API, I can do that.
So, Is it possible to export the timeseries of synthtic browser monitor?
Yasuo Ohnsihi
5 REPLIES 5
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Hi Yasuo,
Of course you can, please see the new metrics API endpoint.
https://www.dynatrace.com/support/help/extend-dynatrace/dynatrace-api/environment-api/metric/get-all...
You just have select the synthetic metrics.
Best greetings,
Wolfgang
Hi Wolfgang,
Thank you for your reply. I will check the Metric API.
Best Regards,
Yasuo Ohnsihi
But please wait with the external alerting until next week as we are introducing a new custom event and alert feature that allows you to alert on all synthetic metrics. So I guess that will solve your use-case without exporting the metrics.
Best greetings,
Wolfgang
See a preview screenshot here:
Thank you!!, Wolfgang.
I will check the alerting function!
Yasuo
Hi Wolfgang,
I checked new custom alert function. I understood the function can detect 1 threshold violation.
But the alert mail is too slow. The alert mail is send after about 8 min of detection.
So is it possible to change the timing of alert mail?
The flow is the followings.
- Alert detect at 14:19(JST) = 05:19(UTC)
- Alert mail was send at 14:26:58(JST) = 05:26:58(UTC)(from mail header info)
Support team say the alert detect check function waits 5 min for one more synthetic measure and about 2 min for thinking to alert.
Why the wait time is need? And is it possible to change quick mailing process?
Best Regards,
Yasuo Ohnishi
