question
Sreedhar M. avatar image
Sreedhar M. asked ·
Does Dynatrace supports signalR ?
hi Team,
Any idea if dynatrace supports signalR ? on our website pages we have this library used and recently from August 3rd week sometimes intermittently we are seeing failures caused due to RUM js injection.
Thanks!
dynatrace saasRUMdotnet
Sebastian K. avatar image
Sebastian K. answered ·
You can exclude all URIs that contains signalr path from monitoring on service side. I’m not sure if this will change anything but in such way you will have to validate with different tool or logs. Are you sure that those 500 errors are not happening without dynatrace?
2 comments Share
Yes Sebastian!
After disabling the RUM we haven’t seen these 500 errors but when we enabled it back they occur intermittently.
We have single tenant for multiple environments including both prod and test environments. Is it possible to exclude the RUM monitoring for the signalR only for a specific process groups rather than global?
Thanks!
0 Likes 0 · ·
You can go to process group settings by clicking edit and there exclude RUM injection. That's all :)
0 Likes 0 · ·
Are you sure that failures are because of RUM iniection? RUM is catching all exceptions in console log, because of that DT can show you whole exception messages. Such exceptions are thrown than by dtjsagent again so sometimes it looks like agent is source of errors true stack trace is from the moment when other JS file starts. It is possible that even without JS agent you had those errors but you didn't know. If this is incidentally not constant, it looks like what I said.
Signailir should be transparent for agent, you will se loading of this file, errors but nothing more as I know.
1 comment Share
Yes, Sebastian!
Have opened support case as well SUP-30302 for the same and they have no idea about the issue. Requesting to reproduce the issue and provide memory dump which is not possible as it's intermittent. Please find the screen shot for the exception.
Thanks!
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
