Is there a way to disable the "Availability decrease" Problem in the Dynatrace platform?
Is there a way to disable the "Availability decrease" Problem in the Dynatrace platform? This problem notice is causing too much noise within the platform.
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Do you mean host unavailability? Do you have some hint for us why it is too noisy in your environment? Yes there is a global setting to disable the detection of host unavailability.
Best greetings,
Wolfgang
