Uninstalling OneAgent completely on Windows
charley_li
Contributor
I need to uninstall OneAgent completely on Windows.
I read the documention below and follow the step:
https://www.dynatrace.com/support/help/technology-support/operating-systems/windows/operation/uninst...
But when I try to remove log files, I can't find the path "C:\Program Files (x86)\dynatrace\log"
In other word, It doesn't have "log" directory in the "C:\Program Files (x86)\dynatrace\" path.
I also check the "C:\Program Files\dynatrace\" but I don't find it, either.
What can I do for check that I am already uninstall OneAgent completely or not?
Thanks for help!
5 REPLIES 5
skrystosik
If in you don't have log directory in dynatrace folder than you have deleted agent properly. Does this dierctory contains any extra content? If you don't have any other dynatrace product on this server, whole directory is nod needed anymore.
Regards, Sebastian
Thanks for your answer!
I check the dynatrace path and find it only left the single path and three files below:
Path: C:\Program Files (x86)\dynatrace\oneagent\agent\bin\1.169.191.20190606-154523\any
So I just need to remove these three files to finish the uninstall steps, right?
In my opinion yes.
Regards, Sebastian
Thanks for your kind help!
MAkimov
Mentor
After removal some logs may be located in %ProgramData%\dynatrace\oneagent\log
