questions about tags...
mony_r88
Contributor
Can Tags can be used as a filter for problem notifications?
Are Tags required to process groups to be assigned to specific technology?
Only tagged entities show up in search results?
Does Tag allow custom grouping of entities?
skrystosik
Processes are assigned to technolgoies automatically. Problems can be filtered with tags, tags are as well possible to be send in problem paylod via webhook integration.
Tag can be used for grouping entities this is it's purpose. So you can assing tags as you wish and than use such filter in every available filter field. You can as well use them for management zone.
Regards, Sebastian
