How to chart user sessions that include a particular action?
mony_r88
Contributor
3 REPLIES 3
skrystosik
You have to use USQL:
https://www.dynatrace.com/news/blog/usql-goes-ga-data-driven-decisions-with-powerful-queries-and-adv...
Using such query you can find all sessions that contains particular action according to your needs.
Regards, Sebastian
AK
Pro
You can add filter for that particular user action. Refer a screen grab below,
Thanks...
jonathan_schull
Dynatrace Advisor
Dynatrace Advisor
Hi Monica,
Sebastian is correct, you can do this using USQL. Specifically if you pull data from the usersession table, and check that there is a useraction.name matching the action you are interested in, it will return all user sessions that include that particular action. Here is an example:
SELECT COUNT(*), browserFamily
FROM usersession
WHERE useraction.name = "/easytravel/rest/journeys/"
GROUP BY browserFamily
This will return the count of user sessions, split by browser, that contain the user action "/easytravel/rest/journeys/". Once you get this down you can play around with the metrics you are bringing in to chart exactly what you would like.
Cheers,
Jonathan
