Determination of language and locale defaults
adir
Newcomer
Hi, What are the language and locale defaults and how they are determined?
4 REPLIES 4
skrystosik
Dynatrace is available in English only.
Regards, Sebastian
ben_wrightson
Dynatrace Champion
Dynatrace Champion
Since v 1.233 Dynatrace is available in English and Japanese. Dynatrace respects your browser settings (see https://www.dynatrace.com/support/help/shortlink/release-notes-saas-sprint-233#japanese-display-lang...).
GilesDay
Helper
Would like to see french support. Not sure if this comment will do anything... but hopefully
You have a communtity French group but I do not know how much active it is.
If you are talking about UI, you can raise a product idea.
Best regards
