Percentage Availability rounding in top lists.
Geoffrey_Barlow
Participant
We have a dashboard set up to show the availability and performance of our key synthetic monitors. These consist of a graph of each metric and then a clone of that graph underneath converted to a Top List view.
In the performance top list we see the performance shown as x.xx seconds which is fine.
In the availability top list we see the availability as x%. What we would like is for the availability figures not to be rounded up to the nearest % and instead be displayed with at least 2, preferably 3, decimal places. Does anyone know if it's possible to change the rounding on availability figures for dashboards or is it only possible to see these figures if you drill down into the monitor?
Many thanks
Geoff
skrystosik
There is no such option so far.
Regards, Sebastian
matthew_gardner
Dynatrace Helper
Dynatrace Helper
Hello Geoff,
To add to Sebastian's correct answer: if you have not already, please feel free to submit a Request for Enhancement(RFE) if you would like to potentially see this feature in Dynatrace.
Here is the link to submit a Product Idea:
https://community.dynatrace.com/t5/forums/postpage/board-id/DynatraceProductIdeas
Matt
