question
Adam S. avatar image
Adam S. asked ·
Do Service Request URL cleanup rules and naming rules not work together?
Hi, I am working on adding a request attribute to the request name for a group of service requests. I am running into an issue where some previously implemented URL cleanup rules don't work when the request naming rule is implemented.
The URL cleanup rules were removing a token that wasn't needed in our request names.
The request naming rule adds a request attribute called pyActivity to the end of the request.
We want to be able to have the request name remove the token found in the URL, and add the request attribute to the end of the request. Below are the rules I am currently using to try to cleanup URL and add the request attribute.
URL Cleanup Rule:
Request Naming Rule:
Anyone know if there is a way to make these two rules work together for our request names?
configurationservicesrequest attributes
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
The issue is that you are using URL:path in naming rule. Cleanup rule does not change url path, it is changing request name. (when you go to purepath, you will see full path there without cleanups). There is no placeholder that may use current url name so it may be difficult to make it work like you want. It is good point for product IDEA for adding another placeholder (current name).
1 comment Share
Thanks Sebastian! I will go ahead and setup an RFE for using "Current Name" as a placeholder for the request naming rules.
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
