How to read the value of log analytics consumption in CMC page?
In this screenshot, I can understand where does the 14.03MiB comes from, that's because free 5GB per year translate to roughly free 14.03MB per day
How about the 23.29M in front? I don't understand what is it.
Best Regards,
Wai Keat
skrystosik
You may be right about those 5GB yearly. This actually means that during whole year you can use 5GB log storage but you can consume it faster (after some time storage will expire). For now you are using daily 23.29MB of logs so you are making it faster than free license is allowing. You have any log monitoring event configured in Dynatrace?
Regards, Sebastian
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Yes, that's right 5GiB total quota divided by 365 (days in a year) gives about 14MiB daily.
Senior Product Manager,
Dynatrace Managed expert
