question
asha s. avatar image
asha s. asked ·
awscodepipeline over jenkins project with performance signature
Hi, I'm trying to integrate aws code pipeline over a jenkins project and not a pipeline since the awscodepipeline plugin doesn;t have a pipeline alternative and use the performance signature plugin that is only meant for jenkins piplelines. is there a workaround to using the dynatrace plugin in a jenkins project instead?
extensions
Patrick H. avatar image
Patrick H. answered ·
No, the plugin can only be used with a jenkins pipeline, not with a Freestyle Project.
But you can have a look at Pitometerm which you could use in your jenkins project to do a performance signature without the plugin.
Share
Leon Z. avatar image
Leon Z. answered ·
3 comments Share
It seems you want to use a Freestyle jenkins project that is not a pipeline project, use the Native jenkins link and adapt the steps in the pipeline (sh steps) as steps in your freestyle project.
0 Likes 0 · ·
The accepted answer is an option but the Dynatrace CLI readme states: "The CLI now implements the main uses to gather and compare metrics as part of your CI/CD Delivery Pipeline. All gathered and compared data will end up as a Custom Device with Custom Metrics in Dynatrace, e.g: "My Jenkins Pipeline" with metrics such as "Response Time", "Throughput" or "Number of Incoming Dependencies".
0 Likes 0 · ·
Sebastian K. avatar image
Sebastian K. answered ·
I’m not sure what you are trying to do.
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX timestamp action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
