Answer by Judtih L. ·
So what I know is that the program Aiven supports the requirements that you demand. Kafka in all its versions can be connected to other databases using this provider without creating a big data chaos.
Furthermore, Aiven is cloud based for Kafka and can therefore make data available for anywhere in the world.
Maybe this would be something for your customer?
Answer by Sebastian K. ·
If there are JMX measures for streams you can always create own JMX plugin using JMX editor:
https://www.dynatrace.com/support/help/shortlink/plugins-java#create-a-jmx-plugin
