01 Oct 2019 07:49 AM - last edited on 15 Dec 2021 02:12 PM by MaciejNeumann
I have configured Oneagent on K8S cluster using the following link.
https://github.com/Dynatrace/dynatrace-oneagent-operator/tree/release-0.4
After configuration, I am seeing an error "kube-proxy kube-proxy (kube-proxy-85qvd):Connectivity problem" under Problem section.
Activation of deep monitoring was unsuccessful
Monitoring of statically linked Go programs that do not load libc is not supported
I understand that kube-proxy unable to communicate on a few ports but I am not seeing any errors in Kube-proxy or dynatrace logs.
15 Oct 2019 01:25 AM
We're running into the same issue with EKS
15 Oct 2019 09:01 AM
443 and 8443 ports are opened between k8s containers and CAG/EAG servers?
Download the support archive and check for erros in logs.
Host-->Process and Container(select the process which Activation of deep monitoring was unsuccessful) -->click on the 3 dots and download support achieve.
check the logs for errors.
Mayana Khan
27 Nov 2019 09:05 PM
hello, anyone found the answer for this?
19 Dec 2022 12:53 PM
Hello everyone,
There is now an article in Dynatrace documentation about troubleshooting issues on Kubernetes, including connectivity issues. You can check it out here:
Connectivity issues between Dynatrace and your cluster
