Does OneAgent Operator support labels on OneAgent pods?
brendan_dunne
Newcomer
My company uses OneAgent to monitor our Kubernetes clusters (in AWS EKS). We have recently begun switching from the older Daemonset configuration of Oneagent to Oneagent Operator.
About OneAgent Operator
Is it possible to configure Oneagent Operator to add specific kubernetes labels to the OneAgent pods it creates and manages? In the Daemonset model, it was simple to configure all details of the pods which the Daemonset would manage. The abstraction of the Operator model has me unsure whether there is a way to specify the metadata applied to OneAgent pods.
Thanks!
brendan_dunne
Newcomer
After working directly with Dyantrace support, it seems this feature is not yet available. Following up with a product idea:
https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/231652/configurable-kubernet...
