question
Peeradis S. avatar image
Peeradis S. asked ·
Aggregated IIS Event Session take a lot of time
Hello I try to investigate performance issue about calling api from web ui
Our Architect is
IIS Web -> HAProxy -> K8sIngress -> API
Then i use dynatrace to check where it slow.
I Found That it Spend a lot of in WebUI Not API Side so i check further.
See That Session is consume a lot of time.
How can i find what the root cause for this? Or I need to Contact Microsoft?
IIS version 10.0.14393.0
iis
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
You should go to host => edit and there you can enable early adopter feature about IIS Modules tracking:
after this you will see which module is rootcause. You have to restart iis after this change.
4 comments Share
It Already On
0 Likes 0 · ·
I look Further and See the Session Module is the problem.
But What i can do next to improve performance.
0 Likes 0 · ·
Dynatrace will not help you more here. Problems with session module may have various of reason on IIS:
https://forums.asp.net/t/2154050.aspx?Hang+Requests+in+AcquireReqestState+in+Session+module+after+server+move
For example here. You should check IIS forums that are corresponding to this topic.
0 Likes 0 · ·
Thank you @sebastian k.
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
