Monitoring application within saleforce
vikram_narawad1
Participant
Hi Team,
We are not able to see the calls for one of our application deployed on Saleforce
The reason for this is that, since the application is rendered inside the salesforce pages, Dynatrace does not inject the Ruxit agent.
Is there any solution to get this issue resolved ?
skrystosik
If you are able to inject agent manually you can do it that way.
Regards, Sebastian
marco_mannucci1
Inactive
Definitely go the Agentless route. We are doing something very similar although there are some issues with some pages which require more inventive approaches to the manual injection.
