Can I transfer the VM Dynatrace node to another network using vCenter?
MAkimov
Mentor
Can I transfer the VM Dynatrace managed to another network using vCenter?
I have Managed (not offline) installation.
If I move the vm in another subnet then nothing breaks ?
5 REPLIES 5
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
If IP address remains same and network connectivity to there nodes (if there are any) it should work.
Otherwise you need to follow one of the steps described in our migration guide:
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/operation/migrate-a...
I believe in your use case the only option is to use backup and restore in the target subnet.
Senior Product Manager,
Dynatrace Managed expert
Thank you for answer
I have not had monitoring data yet.
I installed dynatrce , but the networkers want to migrate it to another segment. It will be the same vm but it will transfer (I do not create a new machine)
Interested in a question at me that the license after migration was not blocked
If you have nothing yet and the IP will change - maybe it's just easier to reinstall.
1. Remove a cluster and free the license: https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/operation/remove-a-...
2. Install in a new place.
If IP will be same - it should work.
VM will be same , simple it will be migrate to another VLAN ( another ip network)
Do I need re-install Dynatrace cluster ? ( I have not offline mode )
If IP changes - you have to to reinstall or migrate.
