question
Gilles D. avatar image
Gilles D. asked ·
What are the consequence of installing plugin on a process
I have to monitor an HAProxy process, the thing is that dynatrace seems to doesn't see it fully, so installation of a plugin is required. My questions are quite simple:
- what are the consequences if I install those plugin execept the fact of monitoring the process ? Will there be any potential problem on other process ?
- My second question is, Is the plugin installation reversible. I Mean in cse of issue can we just remove the plugin ? or disable it ? like nothing was install ?
- Can anyone explain me why does Dynatrace display login box and an url box for plugin installation ? which credential should I used ? which URL should I enter.
Just for information I'am using Dynatrace managed
Dynatrace Managedextensionsmonitoringinstallationtechnologies
1 Answer
Jakub M. avatar image
Jakub M. answered ·
Plugin installation is not needed it is embedded into every OneAgent. Plugin use API expose by HAProxy and binds metrics to its process. In case of rpoblem you can just disable the plugin. It will be disabled on all hosts automatically. Defult HAProxy URL is http://localhost:1936/stats please read more about configuration here https://www.dynatrace.com/support/help/technology-support/application-software/other-technologies/supported-out-of-the-box/haproxy/
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
