question
Ravikant M. avatar image
Ravikant M. asked ·
integration ->problem notification -> email integration-> add custom placeholders
Hi Team,
Can we have custom placeholders in integration section while integrating a problem notification with other notification systems i.e email integration.
Example : Adding a custom placeholder for customized URL that can be added to the subject.
It can be a good feature if we can add custom placeholders. @kavya hiremath @jarett
Ravikant Maurya
alertingproblem detection
1 Answer
Wolfgang B. avatar image
Wolfgang B. answered ·
Dear Ravikant,
Can you please explain a bit what you would like to do with that placeholder? As we are filling the placeholders on the fly, where should we take the value of the placeholder in that case?
Best greetings,
Wolfgang
1 comment Share
I would like the ability to put a property from a custom plugin into the problem notification. We have a custom plugin that looks at JMX properties, and I would like to be able to put those properties into the Notification, for quicker alerting without having to drill down into the problem. @Wolfgang B.
0 Likes 0 · ·
