How to get response time and failure rate for specific service using Dynatrace SaaS API?
khaled_omar
Newcomer
What API should I use?
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Hi Khaled,
You should use the new metric API. See the documentation here:
https://www.dynatrace.com/support/help/extend-dynatrace/dynatrace-api/environment-api/metric/
Best greetings,
Wolfgang
khaled_omar
Newcomer
@Wolfgang B.
Can you tell me what I need in the parameters, beside the selector, in order to get the current value?
Thank you
