Availability of process metric to custom dashboard
MAkimov
Mentor
Hello
We have Availability indicator on process page.
I want to add this metric to my dashboard but I do not find any way.
Coluld someone tell how to do it?
10 REPLIES 10
Babar_Qayyum
Hello @Mikhail A.
I guess for the time being there is no custom category to plot something processes related including the availability.
Babar
it is strange
RomanW
Dynatrace Champion
Dynatrace Champion
At the moment, availability metrics aren't supported to be charted or alerted on, but we're working on that. Nevertheless, a number of general process metrics can be found under the metric registry Path Technology > Generic
@Roman W. Is there update on process availability metrics? This is critical metric for any operation. I know this is available through API but why it is restricted for custom chart?
steven_torres
Participant
Has there been any updates regarding Process Availability charting? I have some key processes that do not run services but the application owners would like to see when those processes stop from a dashboard perspective. I know we can turn on the alerts for graceful shutdowns but we would like a dashboarding ability for this same metric. Any info on this enhancement?
Randall_Howarth
Contributor
Chiming in here, we also would like to get process availability into a custom chart
ThomasEaton
Helper
Is there a metric yet, for process availability? = we have the option for Process Availability Alerts at the group level.
andra_nosa
Helper
Is there process availability yet?
I need to create report montly for this
Mahdi24322
Frequent Guest
Need the process availibility % as metric to use for dashboards or metrics
thanks in advance
LuisnaviaTE
Frequent Guest
You can use process availability % or builtin:pgi.availability
