09 Oct 2019 12:34 PM
Hello
I noticed a small bug on the technology page.
I have some process and add tag for it
but when I try to configure the filter on the Technologies Page it gives an error
09 Oct 2019 12:50 PM
Can you try to put the tag on the process group page? Are you sure it is not a timing delay issue?
Best greetings,
Wolfgang
09 Oct 2019 12:57 PM
Hello Wolfgang
I adde tags either to Process and process group page.
Maybe a problem that the type of technology is other ?
25 Oct 2019 09:32 AM
Hello @Wolfgang B.
Do you have plan to add the ability to filter by user tag in the technology section for processes type other
currently it is not possible
