Mobile problem notification
henk_stobbe
DynaMight Champion
DynaMight Champion
When an alert is pushed to a mobile, the mobile will retrieve problem details.
Does he use the standard API for this? but then on port 9999?
https://{your-domain}:9999/e/{your-environment-id}/api/v1/problem/details/{problemId}
(in other words can I test the connection with this link)
KR Henk
Julius_Loman
DynaMight Legend
DynaMight Legend
Yes, it uses also this endpoint and also other ones. The port depends on your Cluster ActiveGate configuration and the public address for the Cluster ActiveGate.
