IBM Integration Bus & calls to Oracle DB
vladislav_samoy
Inactive
Hi all
Have a question regarding calls to Database done by jdbc driver inside Integration Bus process.
In a PP we can see JavaComputeNode invocation & time spends there (4-5sec). In this specific scenario IB run java process, that creates call to DB
I do remember that we can instrument java inside IB manually with AppMon (we did it with one customer and then we saw call to DB from IB).
With Dynatrace we do not see such java processes which queries Databases
How to achieve this with Dynatrace?
4 REPLIES 4
D_Miller
Advisor
As far as I know at present this is not possible as it's something we've been requesting too. Last I heard was that it was being looked into.....
Hello @D_Miller
Do we have any updates/progress on this subject?
Babar
janusz_dabrowsk
Dynatrace Pro
Dynatrace Pro
Hi Vlad,
I support Darren. Yes, this is not currently supported and PMs know this request.
fstekelenburg
DynaMight Pro
DynaMight Pro
Is this still a valid topic? Of should we "close" it b/o 'old age'?
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | measure.works, Dynatrace Partner
