Api Call host.availability - details for possible value
Hello every body,
I'm extracting data for host availability from dynatrace managed via this timeseries metric com.dynatrace.builtin:host.availability
When I read the data I see different values but I'm missing the meaning for some of these:
AVAILABLE (The regular available status when oneagent is sending data and the host is up and running)
INITIALIZING
NOT_AVAILABLE (When an host has been gracefull shutdown or it went down for any other reason)
UNMONITORED (When an agent is uninstalled)
MONITORING_SIGNAL_LOST
UNKNOWN
Can someone give me better insight for status INITIALIZING / MONITORING_SIGNAL_LOST / UNKNOWN?
Is there a "in maintenance" status?
This is what I found about availability on the docs:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/problem-detection-and-analysis/basic-con...
This is what I found about host.availability timeseries metrics status on the docs:
https://www.dynatrace.com/support/help/extend-dynatrace/dynatrace-api/environment-api/timeseries/
Julius_Loman
DynaMight Legend
DynaMight Legend
I don't think this is publicly documented, but my guess:
  • AVAILABLE (The regular available status when oneagent is sending data and the host is up and running)
  • INITIALIZING - agent is starting up (initial beacon?) but did not send any data yet
  • NOT_AVAILABLE (When an host has been gracefull shutdown or it went down for any other reason)
  • UNMONITORED (When an agent is uninstalled)
  • MONITORING_SIGNAL_LOST - agent disconnected (network issues probably)
  • UNKNOWN - nothing from above
Maintenance won't be there since maintenance is defined on a more granular level (host / process /service/..) and not on the agent itself.
