Can Dynatrace Synthetics utilize a machine's WPAD file instead of going through the proxy?
Jennifer_Kunkel
Newcomer
Would like to know if Dynatrace Synthetics (either within ActiveGate agent or within the script) can utilize the routing information found in the WPAD.DAT file rather than routing through the proxy on private Synthetic locations?
nicole_king
Dynatrace Promoter
Dynatrace Promoter
Thank you for your question. This is not currently supported. However, it is being considered with no time frame for availability.
