Ignored JavaScript errors Template
snakhuda
Participant
Is there an option to create "Ignored JavaScript errors" list and apply to an application or multiple applications. Or is there is an option to take ignore list from one app and apply to another app?
3 REPLIES 3
skrystosik
So far I don’t know any option for making such exclusion globally. As well there is no api object that can be used for exporting such settings and importing to another app. Kind of good candidate of product idea 🙂
Regards, Sebastian
@sebastian k. -- Thank you!!
KlausEnzenhofer
Dynatrace Champion
Dynatrace Champion
Currently not planned
