question
Vlad S. avatar image
Vlad S. asked ·
Davis's analyzed dependencies amount
Hi all
Just curious about number of dependencies, which is showed in the problem description
I have a AG plugin which gets some value over REST API and if the number is higher than something, it shows the alert. Simple logic, but the problem shows huge amount of dependencies and it looks like random value.
@Wolfgang B. can you explain a little bit in details please?
davisai
Wolfgang B. avatar image
Wolfgang B. answered ·
Can you please post the screenshot again, its not properly showing up in your post. Davis dependencies analyzed does show the existing combinatoric product of monitored entities in your system that Davis has to check for connections to your problem. In case your problem is not connected to anything at all, Davis still identified that by ruling out the other monitored entities and their relationships.
Best greetings,
Wolfgang
1 comment Share
Here it is
So does it mean that for custom AG plugin alert, Davis still do analyse possible anomalies on all entities (even if they are not connected with each other)??
0 Likes 0 · ·
Sebastian K. avatar image
Sebastian K. answered ·
It's not random value, each process / host /service /application has mutliple metrics and correlation between them. This results number of analyse dependencies :)
1 comment Share
Here I have 2 metrics in this AG plugin without any mapping to existing entities. And 1 alerts defined within the plugin.
I dont get what to analyze here
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
