question
Wai C. avatar image
Wai C. asked ·
When Adaptive Load Reduction is activated, does the throughput graph gets affected as well?
When ALR is activated, I understand the number PurePath captured will be reduced.
How about metrics? (especailly Throughput. CPU & REsponse TIme & Failure Rate I didn't really interested that much.) Will be make the throughput in the chart lower than it actually is?
I am running a load test now with 10k concurrency, it happens that right now ALR is activated and I see that the throughput at the service there is only 3k. So, want to know if it is only some load testing scripting issue causing this? or also ALR is playing a part in here as well.
Best Regards,
Wai Keat
dashboardDynatrace Managedpurepath
1 Answer
Julius L. avatar image
Julius L. answered ·
Not service metrics such as throughput is not affected by load reduction. We have several environments where the load reduction is applied and also the default limit of 1000 PurePath/process is set and the throughput is much higher.
For example a service (provided by 4 processes), total service throughput is at the moment 38k requests / minute.
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX timestamp action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
