JIRA integration test failed. HTTP Response Code: 400 - Bad Request
jegonzalez
Newcomer
I am trying to integrate JIRA with Dynatrace SaaS and I'm receiving the next error message
Reason: Non successful HTTP response.
HTTP Response Body:
Is a configuration missing on my Jira Server?
6 REPLIES 6
jegonzalez
Newcomer
HTTP Response Body:
{"errorMessages":[],"errors":{"customfield_10113":"Source is required.","customfield_10110":"Dimension is required."}
There are certain fields which are missing, do you know if you have any such fields?
silvia_moreno_u
Inactive
Hi Emmanuel,
We need a bit more info, could you show us your configuration in Dynatrace? (masking confidential data of course).
Regards
Silvia
yes of course!
this is my configuration
Hi.
I share with you my screen of my configuration.
Additional in the JIRA server I have already added the Dynatrace ip to the host.
I have already tested TELNET from the JIRA server to the Dynatrace server and it was successful but it still does not connect.
Am I missing something?
JIRA endpoint URI:
http://11.11.11.11:443/rest/api/2/
jemartineza
Participant
Hi
I share the link on how to add Jira certificate to the Dynatrace Server
https://community.dynatrace.com/questions/249520/view.html
