Automatic cluster updates setting disabled?
hi All,
In the CMC settings am unable to enable the auto cluster updates as the option is disabled? Any idea why?
Server is connected to Mission Control without any issues
skrystosik
According to alert you see it was disabled manuall by Dynatrace employee. Try writing to Dynatrace one on built in chat in Dynatrace.
Regards, Sebastian
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Hi @Sreedhar M.,
We are releasing all our updates in a staged fashion to all our customers. Once we observe some issues or regression after the deployment, our Mission Control team pro-actively suspends all roll-outs of updates until the issue is resolved or clarified. This significantly increases the effectiveness and resilience of upgrades.
Stay tuned for the next update that will be delivered to our automatically. Once it's done, you will gain an ability to trigger that yourself.
Senior Product Manager,
Dynatrace Managed expert
