Issue with selfsigned certifcate kubernet setup
shailendra_jain
Newcomer
Hi
I have tried setting the kubernet monitoring as per document .. but i have been always getting TLS issue for self signed certificate .. or even invalid token sometime ..
1. Using Keytool - imported the certificate in existing trusted.jks file with passwod trusted
2. Adding entry in custom.property file also .
3. Restarted all gateway/agent ..
4. Enter the kubernet URL and token but getting TLS or invalid token issues
Also tried with no certificate options also.. then getting same TLS issue ..
Note : Agent/gateway installed on same rancher-kubernet cluster node ... my server is on different node.
I am able to see docker images due to agent on that node ... but API/Token failing for TLS.
Q: What is right step for connection...
Q. Is it fine to use existing trsuted.jks ( i have tried even with jks file)
Q. Will not this work with self signed certificate
Q. Is certificate need to be generated on a node where agent and activeagete installed ?
skrystosik
We had similar issue, you have to add your ROOT CA certificate to ActiveGate, than it will accept certificate you have on Kubernetes side.
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-activegate/configuration/co...
Regards, Sebastian
Thanks Sebastian!! ... We notice .. it does not work with rancher certificate ..But work with Kubernet directly.
