question
Jeff R. avatar image
Jeff R. asked ·
APDEX settings for SESSION
I see that an overall APDEX rating is provided for each user session, but I can find nothing in the documentation that explains how this is calculated or whether the settings can be adjusted. The documentation mentions, as far as I can see, only APDEX calculations for individual user actions. Can somebody tell me how this APDEX is calculated and tell me whether I can adjust the related settings?
configurationDynatrace ManagedRUMdocumentation
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
It's easy, you have apdex for each user action and based on this is calculated apdex for user session. If you are interested in how apdex is calculated for user action:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/real-user-monitoring/basic-concepts/ratings/apdex-ratings/
3 comments Share
I'm afraid that I do not understand your answer. Each action can obviously have a different APDEX value… how DT handles that to produce an overall APDEX evaluation for the session is not explained.
0 Likes 0 · ·
Thanks. The information provided on "User Experience Score" is exactly what I was looking for.
0 Likes 0 · ·
