question
Melissa H. avatar image
Melissa H. asked ·
What are the differences between AppMon and Dynatrace regarding apdex calculation?
We recently moved from AppMon to Dynatrace Managed. Some of our applications are experiencing lower apdex scores. One thing I see is that Dynatrace Managed has an option to include java script errors in the apdex calculation. I see that we can turn that on/off. I don't remember seeing it in AppMon. I assume Java Script errors was not included in the AppMon calculation. Is that right? Are there any other major differences?
appmonDynatrace ManagedRUM
Vlad S. avatar image
Vlad S. answered ·
Hi
As far as I remember AppMon calculated connection speed as well. Dynatrace does not track user's connection speed
1 comment Share
I remember we had the ability to capture connection speeds in UEM (AppMon) if we wanted to, which was cool, but we rarely turned that on (due to the warning about causing network overhead). Just to make sure I'm not missing anything though...does the fact that RUM (DT Managed) cannot calculate the connection speed impact the results of the apdex calculation?
0 Likes 0 · ·
Joshua P. avatar image
Joshua P. answered ·
Good morning, Melissa H.!
The documentation regarding Apdex in Dynatrace can be found here:
https://www.dynatrace.com/support/help/shortlink/apdex
Dynatrace SaaS/Managed uses "Visually Complete" as the metric source by default, and also sets 0-3s as Satisfied, 3-12s as Tolerating, and 12s+ as Frustrating. Additionally, JavaScript errors experienced during an action will cause the action to be Frustrating.
Dynatrace AppMon, if my memory serves correct, used "User Action Duration" instead of "Visually Complete" and didn't bring in JavaScript errors into its calculations.
Kind regards,
Joshua P.
2 comments Share
Thanks! We did catch the "visually complete" vs "user action duration" and set that (as well as our response time thresholds) to match our settings in AppMon. It must be the java script errors.
0 Likes 0 · ·
You're welcome, Melissa H.!
Based on the information you've provided, that would be my guess too!
Kind regards,
Joshua P.
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
