question
Dattatray M. avatar image
Dattatray M. asked ·
Dynatrace API to fetch configuration information of Host and Process.
How can I fetch configuration parameter from Host and Process using Dynatrace API.
I need to fetch below parameters:
Host Level
  • Operating System
  • CPU (Family, Speed, Cores, Architecture)
  • Memory
  • Disk (Mount Points with allocated quota)
  • Network Cards (Bandwidth, IP Address)
Process Level
Incase of Java Process
  • JVM (version, vendor)
  • Heap Allocated (min, max)
  • GC Policy
Thanks and Regards,
Dattatray Madake
Dynatrace Managedoneagentdynatrace saasrest api
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Share
