Refused to execute script from 'http://X.X.X.X/test/ruxitagentjs_ICA27SVfghjqrux_10177191024092634.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
deepanshu_arya
Inactive
We are getting below error whenever trying to enable BRUM JS automatically in one of our application.
Refused to execute script from 'http://X.X.X.X./test/ruxitagentjs_ICA27SVfghjqrux_10177191024092634.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
We tried to investigate the issue and observed that content-type of this JS is being changed from "text/javascript" to "text/html" somehow..... Please suggest if you guys have any idea about this.
Deepanshu
AlexanderSommer
Dynatrace Champion
Dynatrace Champion
Please create a Dynatrace support ticket as this seems to be an issue within your environment: https://www.dynatrace.com/support/contact-support/
