question
Antonio V. avatar image
Antonio V. asked ·
Openkit, support using a proxy?
Our customer is instrumenting a fat client application with Openkit (.Net). On the developer workstation we receive data and works fine. Then, they installed the instrumented version on the customer environment (developer servers first), where you need a proxy to access the internet. In the customer environment, no data is received when they runs the application. From that server, the beacon URL can be accessed from a web browser.
In this scenario, how you indicate Openkit library to use the proxy?
Thanks in advance.
Antonio V.
dotnetapplication monitoring
1 Answer
Julius L. avatar image
Julius L. answered ·
I don't think there is any built-in support for proxies right now in any Openkit implementation. Did you try to set the systemwide proxy for the NET itself?
Share
