How can I downstream method calls in [IIS Internals]
olivier_ebaach1
Contributor
Response Time in IIS Internal is 11 seconds, it's important. I want to know witch call or action take that time
3 REPLIES 3
skrystosik
Did you enabled visibility for IIS modules on host settings?
Regards, Sebastian
Yes I enabled visibility for IIS modules on host settings.
And you've restarted IIS after this operation? If it's still in IIS internals you may need other tools like DebugDiag or PerfView (both from microsoft) to investigate.
Regards, Sebastian
