question
EBA'A O. avatar image
EBA'A O. asked ·
DynatraceIntegration-4.0.6.jar
When using DynatraceIntegration-3.0.1.jar I have data in External Data.
But When using DynatraceIntegration-4.0.6.jar with Neoload i have an issue, no data in External Data.
Best Regards
rest apinetwork
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Isn't this integration developed by neotys by themselves? If yes this may be rather question to them, because if one of versions is working, then it may be related to some extra configuration or bug in this jar.
https://github.com/Neotys-Labs/Dynatrace/releases/tag/4.06Beta
As you can see on their github it's experimental. You should open ticket on github page related to this package.
Check as well if this workaround isn't your case;
https://github.com/Neotys-Labs/Dynatrace/issues/4
Share
