question
Aaron M. avatar image
Aaron M. asked ·
Mount NFS disk?
I'm trying to configure backups and can't seem to figure out how to mount the NFS target to any of my cluster nodes.
Any insight? What is the linux command that should allow me to do this successfully?
Thanks!
configurationlinux
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
2 comments Share
not directly. you have to install NFS support on a dynatrace host? it's not installed by default?
0 Likes 0 · ·
For dynatrace itself it should have no difference if this is nfs disk or other if it is mounted in OS. So in general it rather Linux question, not DT one. You should follow this or other guide, if there are some dependencies needed you may have to install them.
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
