What's the difference between system load 5 and system load 15?
Wai Keat
Dant3
Pro
Hey @Wai Keat C. is the load average of linux:
https://www.tecmint.com/understand-linux-load-averages-and-monitor-performance/
1 minute. 5 minutes and 15 minutes
Should be the same info you get from top command.
Services Solution Engineer @PowerCloud - Observability/CloudOps Certified / Former SE @Dynatrace.
