Custom plugin stopped working - Spring boot
Bert_VanderHeyd
DynaMight Pro
DynaMight Pro
Recently a custom plugin I wrote did not work anymore.
It is a oneagent plugin written for a specific Spring boot application which does not activate anymore. I guess something has changed.
What I already saw is that recently the name changed from the process group. It used to be someting like scheduler....jar (name of the standalone jar file) and now it is:
"SpringBoot **.****.scheduler.SchedulerApplication (dev)"
So, I already modified the plugin.json to:
"processTypeNames": ["TOMCAT"]
"activation_name_pattern": "^SpringBoot be\\.inburgering\\.scheduler.SchedulerApplication.*$"
According to the latest docs it looks to the process_instance name.
And I am not sure about "TOMCAT" as processType. My previous version which worked used "JAVA"
Bert_VanderHeyd
DynaMight Pro
DynaMight Pro
I found it...
Reason was indeed the process group name change.
following is working for me:
"name": "custom.python.***-scheduler-plugin",
"version": "1.6.17",
"type": "python",
"entity": "PROCESS_GROUP_INSTANCE",
"processTypeNames": ["JAVA"],
"source": {
"package": "***_plugin",
"className": "***SchedulerPlugin",
"install_requires": [   "requests>=2.6.0"  ],
"activation": "Singleton",
"activation_name_pattern": "^.*scheduler.*$"
processTypeNames is indeed JAVA in stead of tomcat and for the activation_name_pattern it looks at the process group name. This information can be found in the pluginDevLoggerPluginEngineDefault.log. It may be a good idea to explain this a bit better in the documentation. It took me some time to find it.
...ProcessSnapshotEntry(group_id=17701666967535205482, node_id=0, group_instance_id=11233226343147840351, process_type=10, group_name='SpringBoot be.inburgering.scheduler.SchedulerApplication (dev)', ...
But the main issue was in the Python script itself where I took the pgi by name. Since the name was changed, because of the new "Spring boot" support (which I like a lot), it did not find a process instance.
So I replaced it with:
pgi = self.find_single_process_group(lambda pgi: pgi.group_name.startswith('SpringBoot be.inburgering.scheduler.SchedulerApplication'))
Note that I can't use the pgi_name function anymore because that does an "equals" and the name now includes the spring.profiles.active at the end.
