question
Antonello C. avatar image
Antonello C. asked ·
Mobile App data collection seems disabled
Hello
We are trying to monitor an Android app with oneagent, and after some testing, Dynatrace is not showing any user action for this app.
However, even if encrypted, tcpdump shows network traffic exchanged between the mobile phone and the cluster active gate endpoint IP.
In this situation, the troubleshooting instructions from Dynatrace manuals, recommend to test this url:
https://<psg-url>:<port>/mbeacon/<environment id>?type=m&p=<app id>
https://<Active gate IP>:9999/mbeacon/9f06b27f-7116-47d6-8165-15826479ed49?type=m&app=567f5551-c41e-4ffe-96da-79206e6e18b2
that shows this response:
type=m&cp=0
this mean the data collection is disabled for this app (the response contains the string; cp=0).
How can I enable the data collection ? Please consider that the mobile application in Dynatrace is still enabled (monitoring ON).
Antonello
oneagentRUMmobile monitoringmobileapp
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Did you have configured ActiveGate as Entry Point for beacons data in application configuration? You can switch it there to accept beacons on extra endpoint on API (if it is monitored by OneAgent). Maybe someone has changed it?
4 comments Share
Hi Sebastian
this is how the mobile application is configured, so it send data to Cluster Active gate:
The cluster Active gate has this endpoint configuration:
This the result when I browse the beacon url:
and seems the data collection is disabled, the appid and enviroment id in beacon url are from the app definition instruction for monitoring the android app
please let me know if I miss something.
thanks
0 Likes 0 · ·
cp=0 means as well that application id is unknown. Are you sure that you have proper application Id in url?
0 Likes 0 · ·
HI Sebastian
I've got the appid from the application definition in Dynatrace, this is the screenshot:
is this right?
Antonello
0 Likes 0 · ·
it seems to be ok. Open support ticket then, may be best option to resolve your issue.
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX timestamp action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
