Dashboard Timeframe Syntax
I want to set the timeframe of a dashboard to last month. As I understand the synthax this should be possible by using "last month". But in reality this seems to somehow be the same like -30 days.
I think this is just wrong. Or can someone explain it to me? thanks.
Thanks for the feature anyway, I think it will prove itself helpful in future.
HannahM
Dynatrace Leader
Dynatrace Leader
Hi Mathias,
'previous month' should do what you want.
Best wishes, Hannah
Thanks a lot! the keyword did not show up in the synthax and dynatraceone couldn't help with it! your the best!
